Bedlam's avatar
Bedlam
Moderator
Dec 10, 2016
7500 lb Rated Bags
Airlift has a new 7" airbag system for pickup trucks with a 7500 lb load rating at 100 psi. I wonder if these would have more or less bounce than the smaller 5000 lb rated bags available. I'm not affiliated with this company and generally steer people away from bags under a truck camper, but others may be interested in this new LoadLifter 7500 XL.
  • HMS Beagle wrote:
    The spring rate of an air spring is proportional only to the height of the spring, and independent of the diameter. That may seem non-intuitive, but it is true. So unless they are taller than their 5000 product, the spring rate will be the same, and the "bounce" will be the same.
    7500lb. bags at the same PSI as the 5000lb. bags are going to have a higher spring rate. To get the same spring rate in a larger diameter bag, you won't need as much pressure, which will lower the spring frequency, FWIW.
    Personally, I've never noticed the dreaded bounce with airbags and good shocks.
  • No more mistaking air bag for air spring.
    First one is spring
    the 2nd one bag
    Different construction, different principals, different characteristics.
    I was driving F450 with 5000 lb air bags and even with 10,000 lb payload, I not always inflate them fully.
    Meaning you might have no use for bags that will lift the bed higher than normal level.
  • Thought number one is I hope they have upgraded the bracketry, since the 5000 brackets break with some regularity.
    Thought number two: how much "bounce" is primarily related to spring rate. The spring rate of an air spring is proportional only to the height of the spring, and independent of the diameter. That may seem non-intuitive, but it is true. So unless they are taller than their 5000 product, the spring rate will be the same, and the "bounce" will be the same.
