If they can make a 10 speed transmission with the required torque rating, I'm not sure why you would argue that you want less ratios to choose from for varying grade hills, headwinds, hauling weights, etc.
EDIT: Based on current 10 speeds, I would guess max overdrive will stay the same for the most part. But you will have less gear spread and much lower low gears without big gaps between them.
Just because you don't NEED it now, doesn't mean it isn't better.
I think its a great idea, gas or deisel.
