JimInMich's avatar
JimInMich
89,000 miles on a Ford C6 trans
I have a class A that has a C6 auto trans. Mileage is 89,000. Fluid looks ok. Shifts fine, no problems that I could tell.
I know this is a " Crystal Ball " type question, but would you trust this trans to make a trip from northern Michigan to southern Arizona ( round trip )?
Our trip plans are doing Route 66 as much as we can. Speeds will be kept at 55-60mph ( we're in no hurry ).
It would cost about $2000-$2200 for a rebuilt, but our budget just couldnt afford that AND the trip.
It has a medium size trans cooler now. I was thinking of upgrading to a larger cooler.
I haven't weighed the motor home yet, but assuming it is in the 13,000-16,000lb range by what I got from the original manuals.
Motor has no worries, it only has 6,000 miles since rebuild.
Moderators: I posted here so I could get info from some P.U. truck guys ( instead of posting it in the class A section ).
  • If you are taking a trip and cant afford something if it breaks along the way you may want to reconsider the trip?!
    BTW, the trans should be just fine!
  • Personally, I don't fix things that are not broke.
    i only service according to mfg recommendations.
    So you know what I would do.
  • Got to agree with the first response. Service the trans, including flush, filters and fluids, then see how long it will continue to provide trouble free service. I do mine every two years, which works out to 30K miles lately. It's ten years old, and trouble free. I wouldn't spend a moment of time thinking about upgrading coolers or rebuilding anything until it's been properly serviced and run until issues are evident, and I'm betting you will be fine.
  • rhagfo's avatar
    rhagfo
    Explorer III
    The C6 was one of Fords great transmissions, fluid and filter change. I use to do my own and on the C6 I would drop the pan, clean the pan new filter and gasket. Then add the normal 5 qts. or so to fill the
    Pan!
    Then I would disconnect the cooler return line at the pan, have about 16 qts. handy then have DW start the engine, then start adding fresh fluid down the dipstick tube while watching the color of the fluid coming out of the return line. During this time DW was slowly shifting through all the gears, did I mention parking brake ON and wheels BLOCKED? Once the fluid coming out the return line looks clean and fresh, shutdown engine, reconnect the return line and check level and top off as needed, almost a 100% fluid change.
