Gjac
Aug 12, 2017Explorer III
HD and Loews sells a epoxy paint that can be applied with a brush and also a spray version. I used the brush version in a FG bath tub to cover small hairline cracks which stained the tub. It came out well. You can make structural repairs with any FG cloth and epoxy resin then paint or spray over the repair with this epoxy paint which is like a gel coat. Remember if you apply gel coat too thick it can crack over time it should be less than .020. Gel cote is pure resin which is very brittle, that is why you see cracks in FG boats or RV caps. The epoxy paint has additives that make it more ductile. If you decide to go with marine stuff there are many shades of white, they sell tints that can be added to the white gel cote that can closely match your original white. Also the floor needs to be well supported underneath to prevent flexing and cracking the gel coat.
44,056 PostsLatest Activity: May 04, 2014
