DiskDoctr wrote:
I think the previous poster meant to clean the condenser on the AC unit. Take the plastic shroud off the outside and clean out the squirrel's nest and other debris. Might use a hose, too, but not enough to damage the fins and from the inner side outwards (otherwise you may spill water into your RV.
Hope this helps.
Also, while cleaning the condenser, clean the evap. coil as well. As noted this is done outside. While doing that check for critter nests and clear as needed. Also, these units can be charged but there has to be access valves added in both the hi and low side lines. It's a simple process for someone that has the proper equip.
