smkettner wrote:
mileshuff wrote:
My A/C unit had stopped blowing cold air. Took it to three different shops. All told me that the freon had leaked out and there was no way to refill even if they were able to fix the leak. There are no ports on the majority of RV A/C units in order to recharge. Is this true?
Yes they are a sealed unit. Some technicians will add a high/low port to recharge but you still need to repair the leak. And you are still running an old unit prone to leaking again. Generally by the time you do all this you are close on $$$ to just replacing the unit that will include full warranty etc.
I figured if the freon leaked once, it'll leak again. We surmised that since we didn't run the a/c in over a year, the seals probably dried up and that would be where the leak(s) would be.
Yeah, it was an expensive repair job (new a/c unit for the Roo and then a new TT for us!), but the new owners of the Roo have a year warranty on the new unit.
