D1trout's avatar
D1trout
Adding a basement to a C11
Gents, I will be taking the shell off the chassis of my C11 soon. Rebuilding the chassis in aluminum gives me the opportunity to modify things a bit. The benefits of a basement have been mentioned in various posts. Can anyone give me their thoughts about how that would work on a C11? I don't want to compromise the interior height of the camper. This means the extra space goes below the existing floor. That raises the camper up off the truck bed.
Is that an issue? I already have about 2" of space between the bottom of the wings and the top of the truck sides. Is it true that the camper is designed to sit on it's bottom on the truck bed. The wings are not supposed to rest on the sides of the bed?
Adding 4" of vertical space beneath the floor would give a potential for 70+ gallons of liquids! I could put the gray water and fresh water tanks there, custom made within the frame. No black water tank in this rig; I'm using a cassette toilet. The fiberglass unit which now holds tanks could be converted to outside storage and the gray water hose/drain assembly.
I'm also thinking to add hatches to the vertical sides of the wings to allow access to the actual truck bed, again with the idea of increasing storage. Plastic bins or waterproof duffles would serve.
Your thoughts, as always, are greatly appreciated
Dick
  • Some of the old Northlands used to have the floor joisted length wise w/2x6 stood up ,insead of side to side w 2x`s as most wood campers , that allowed the grey tank to go between the joist on one side and made room for a long drawer on the other, I thought that was a great idea
    If you already had to lift an older camper up to clear the cab and side rails , like many do on newer Fords , why not build a platform like that for the camper to sit on, given it would raise the center of gravity
    That would only work with truck box length campers as I think about it,
    unless you moved the grey tank if it was rear mounted above the bumper
  • This one of the best Ideas I've read about around here in a long time.
    Just think.... TorkLift making even a portable storage basement for TC's. Made of Aluminum plate, say, 4 inches high for the small one with pull out tray/drawers that slide out the back.
    I don't know... but sounds good to me
