wintersun
Aug 30, 2013Explorer II
daveshan wrote:deltabravo wrote:daveshan wrote:
My latest direction however is putting 2x100w panels on top wired in series
I think you meant to say "wired in parallel"
Wiring in series increases (doubles) the output voltage.
I have two 150 watt panels on my AF, and would like to upgrade to AGM batteries, because the wet cell batteries are failing, and it's impossible to check the water in them without un-wiring them and completely removing them.
Nope, wired in series, gets the voltage up there and the MPPT controller steps it back down, more efficient in low light like early mornings/clouds etc. Now if I used 100w/24v panels then series would be the way to go.
You have it backwards. Any shading and a panel's output can be cut by two thirds very easily regardless of the diodes employed. Higher voltage does nothing in terms of efficiency beyond minimizing current loss from the panels to the controller. My run from the panels to the controller is less than 8 feet and I used 8ga wire so the current loss is less than 3%. Had I used 12ga wire the same 3% loss would have required 24 volts. I would have looked for two 34 volt panels and still wired in series as the optimum choice.
There is way too much concern about current line loss. As my two 100 Watt panels recharge my 220 AH at 12v batteries in 2 hours of daylight on average, I could have half the current flow and still recharge the batteries in 4 hours which is hardly a problem.
I don't know the specs for the 85 Watt panel that Lance provides but if it provides 34 volts output then the 12ga wiring that Lance installs will not be a problem in terms of charging performance for a single house battery and may be OK most of the time with two batteries in the bank.
