TyandkateExplorerDec 30, 2017Adding electric heat to coleman Mach3+Any one ever added electric heat to there rooftop unit? curious as a option to heat up the camper a bit with out the need of gas. Just curious if anyone uses it and the results.
pianotunaNomad IIIDec 31, 2017If you are concerned about fire, then use an oil filled heater. Their surface temperature never approaches 451 F.
Related ContentAdding power outlets in slide with no wiringElectricElectrical assistanceColemanElectrical outlet issues
