- path1ExplorerLook up the btu's it puts out. Why bother?
- TyandkateExplorerI'll look that up thanks!
Also the add on heat strip for my roof top is drawing the same amount of amps as my unit pulls in cooling mode. - Second_ChanceExplorer IIIt would be more practical to do something like add the CheapHeat unit to the main furnace. Warm air rises, so you would heat your RV more efficiently and evenly using the furnace ducting in the floor. The CheapHeat system adds electric heating to your RV furnace so it doesn't have to burn propane:
CheapHeat
Resistive electric heating also draws quite a bit of current. It would be much more difficult to get heavier wiring up to the roof than doing the modifications necessary in the lower utility areas of the trailer.
Rob
44,026 PostsLatest Activity: Mar 03, 2025
