vtraudt
Aug 27, 2021Explorer
Adding scissor jacks for side to side leveling
My Forest River Salem has electric 'stabilizer' jacks (pivot, won't work for side/side leveling even IF they were strong enough). And the usual front A frame jack.
I do NOT like to drive onto (2x6, lego blocks, curvy plastic thingies, etc). I rather put the trailer exactly where I want it, THEN do all the leveling.
Front/back leveling with the front A frame jack is no issue.
For side to side, I would like to add scissor jacks on (or near, 3/4 points, else) the main frame at each corner. From this weeks stay, it seems that most (all?) not so new trailers have just that. I watched dozens setting up (some with hand crank, some with power drill/impact).
My trailer has a max weight of 7000 lbs.
The main rails are one piece, going from front to back (no welds, no steps).
a) is it ok to 'lift' at the ends or near the ends of the main rails?
b) with theoretically 1/2 of the weight (3500 lbs) on one jack, should I pick 3500 lbs jacks, or go even higher?
I am not sure yet if I will permanently mount (if it works, I likely will), either weld on or bolt on (only reason not to would be weight/inertia added to the rear.
Also, if it works, I would REMOVE the electric stabilizers (the jacks will level AND stabilize) and maybe use the MOTORS (2 on hand. would by 2 more) and add 2 more switches for 'electric' leveling (not AUTO leveling).
Does someone have experience with this modification?
Concerns, suggestions, ideas?
