rogerwaters's avatar
rogerwaters
Advice & Feedback on Truck/Camper Combo Before Purchase
Hi Everyone,
Long-time lurker, first time poster.
I'm just about to pull the trigger on a new truck and camper and wanted to run my specific combo by the community as a sanity check before committing to such a large purchase.
The camper is a new Lance 1172 with most options and I'm looking to put it onto a new Ford regular cab dually with diesel engine. If I can't afford the weight of the diesel, which I do prefer as an engine, then I'll go with the gasser which will do the job just fine as well.
The cargo capacity door jam sticker on the truck that I'm looking at is 6390 lbs. and I've estimated my total payload to be 6280 lbs. leaving only ~110 lbs. of buffer. Now I know that these trucks can handle weight above the specified limits, but I'm one of those guys that doesn't want to be even one pound over these limits - not passing judgement on anyone who sees it otherwise.
To me, this is a decision of whether or not I can afford the weight of the diesel. A big consideration is that I will be launching a boat in the shoulder season where the ramps can get quite slippery. The weight of the diesel would ensure great traction on the front tires when pulling the boat out. Therefore, even if I end up going with the gasser, I am considering sticking with the regular cab in order to shift as much as weight as possible towards the front tires - does that make sense or will the regular cab vs supercab result in very little difference of weight on the front tires?
I'm looking for feedback from the community on this combo and how I am planning on using it. Additionally, and maybe I'm just being paranoid here, but if end up with the diesel, is there any chance that I might end up with too much weight on the front axle?
Base Camper (dry) = 3923
Options = 400
Water (60 gallon) = 500
LPG = 60
Extra Drinking Water = 40
Torklift Talon Tie-down (front) = 30
Torklift Talon Tie-down (rear) = 18
Torklift Locking Guns = 5
Torklift SuperHitch Magnum = 105
Torklift SuperTruss 48" = 83
Torklift Ball & Mount = 10
Torklift Wire Harness = 2
Torklift Stable Loads = 9
Timbrens = 6
Rubber Mat = 48
Rock Tamers = 35
Boat Tongue Weight = 475
Clothes + Personal Effects = 100
Kitchenware = 100
Food = 80
Driver Extra = 50
Passenger = 200
Total Payload = 6279
Truck Payload Capacity = 6390
Excess Truck Payload Capacity = 111
Thanks I look forward to the feedback!
mike
