3940wez12's avatar
3940wez12
Advice for inverter installation
I'm adding a 600 watt inverter and the plan is to put it in the pass thru storage compartment, which will be just behind the batteries on the trailer tongue. My first inclination was to run the cables under the front of the trailer and cut a hole in the floor but to do that I'll have to also cut into the plastic stuff (not Coroplast, kind of like a plastic tarp) completely covering the trailer's underbelly. The more I think about it, the more I worry about being able to completely seal up even a little hole once the cables are passed thru. I think I've seen where someone drilled thru the diamond plate on the front and avoided the underbelly altogether. If so, what kind of junction box, bushing or whatever should I use to run the cables through?
Any advice would be much appreciated by this lady "senior citizen" before I go cutting holes in my TT.
  • What kind of caulk to seal up the plastic under the trailer where the cables go through?
  • If drilling through the wall, a grommet is the thing you need to prevent the cables from chafing. You can fashion one, yourself, using plastic tubing or pipe. Otherwise they are sold all over.
  • You have a good plan by mounting the inverter as close to the batteries as you can. My inverter is mounted on the front wall of the pass-through area to be close to the batteries. My wiring runs out of the bottom of the trailer which also has an enclosed underside as you described. There is sealant around the the wires where they exit the underside cover.
    I also have two transfer switches so the electrical outlets in the trailer are automatically powered when the inverter is turned on. This has been a nice modification.
  • #1nobby, I'm not so worried about the floor itself, it's that plastic stuff that covers the whole underside. So far, there are no holes in it anywhere...and I've crawled under and looked. Wires and plumbing are apparently between the floor and the underbelly covering.
    Another question...is there any reason the inverter should not be mounted to the front wall of the pass through rather than the back wall. The front wall would be closer to the batteries. Thanks for your help.
  • What size is the existing feed to your 12 volt panel? Maybe you can use that? I had a 400 watt unit in my previous rig that I just fed of the neutral and positive feed at the panel, and that put the inverter where I wanted it.
    You might be able to upgrade the feed wires to the battery if need be. For our purposes, the biggest load was the coffee grinder at 160 watts.
    The hole you put through the floor won't be the first on your trailer.
    Holes for plumbing and electrics have already been put in the floor of your trailer by the manufacturer. Do what you gotta do and then blast the hole with some good caulk.
