Gripnriprod
May 07, 2013Explorer
Sure sounds like loose connections. The heat generated will cause the connection to grow worse over time thus heat up and trip the protective device more and more frequently. Apparently it uses a thermal switch that automatically resets once it is cooled down. Don't just tighten the connections as the connectors are likely corroded and may not make good contact. Loosen and inspect them. If there is any sign of corrosion, replace the connectors. If the connection points on the device are corroded, you should consider replacing the device.
44,068 PostsLatest Activity: Jun 01, 2026
