donfla
Aug 19, 2020Explorer
Grit dog wrote:
Weird...
If you saw the motor "jump" when you did a little brake stand,it's broke. If you just saw it "flex" and no "clunk" then it's not broke.
That makes sense. I'm no expert by any means but it appeared to be flexing more than it should. The problem seems to be solved with the new mount installed. Not perfect but I'd rate 90% better, before it would dropout to the point it felt like it was going to stall but never actually did. It didn't throw any codes either. Before taking it in I did a thorough throttle body cleaning using Sea Foam and while it did blow out a good bit of smoke for a second under heavy load that didn't do anything to improve the idle.
44,071 PostsLatest Activity: Aug 30, 2026
