Montana_Mike
Feb 27, 2014Explorer
Air Shocks
What about air shocks on a towing rig. Anyone use these instead of air bags? Or is that to much pressure on the shock mounts?
Ron Gratz wrote:Lynnmor wrote:Are you saying the rear end should be raised to the unhitched height? If so, why?
If you have soft rear springs then even a correctly adjusted WDH will not raise the truck to where it should be.
Ron
APT wrote:
What is your tow vehicle and are you using a weight distributing hitch? IMO, there is no need for adding rear suspension support with a properly adjusted WDH. Using additional rear suspension support tends to mask overloaded situations and makes WDH adjustment more complicated.
Montana Mike wrote:
Ok I'll do air bags. Thanks
