Longtrace
Jul 15, 2013Explorer
AL-KO Kobler U-35 axle, industry part number
I just repacked the wheel bearing on my trailer. Since I had trouble finding part numbers, I'm posting them here for others - and as a backup to my notes. :)
After a bunch of digging, I finally found a AL-KO document that listed AL-KO and Hayes part numbers. This helped a bit, but finding cross references for the rest was not easy.
So here's the list. My axles had 10x2.25 inch drum brakes, with 5 lug 4.5 inch bolt circle wheels. I think these number will apply to any U-35 axle, but I'm not sure
I choose Mystic JT6 grease, available from my local farm supply store. I filled the hub, not just packing the bearings and used about 2/3 tube of grease per hub.
- Inner bearing - L68149
- AL KO #363192, Hayes 093705
- Inner race - L68111
- AL KO #363914, Hayes 093718
- Inner grease seal - 10-19
- 1.719 ID 2.565 OD
- AL KO 568861, Hayes 09103305
- timken 171255
- Redline RG06-050
- Transcom 171255 TB
- Dexter 010-019-00
- National 473336
- NOK AD2548EO
- Outer bearing - L44649
- AL KO #363180, Hayes 093706
- Outer race - L44610
- AL KO #363913, Hayes 093707
- Outer grease cap (EZ Lube) - 85-10
- AL KO #568067, Hayes #09213611
- TruRyde RG01-010
- Dexter 085-001-00
- Molded into the face, “1940”
- Backing plate adjuster hole rubber cap - BP10-220
- AL-KO #568089, Hayes #096932
- Help! has a 4-pack, 13964
