dave17352
May 26, 2014Explorer II
How fast to you drive empty bed? 65 70
How fast do you drive trailering your trailer /5th wheel? 62
With a head wind of 20 mph? 62
Are you being passed regularly on the interstate by traffic, or are you passing everybody else? right in between
Are you retired and in no hurry to get anywhere? not quite retired but no hurry
What is the wet weight of your 5th wheel? 12k
How smooth a driver are you on the throttle and brakes? very smooth
How many miles do you get out of a set of brake pads? lots and lots
How anal are you about servicing your diesel by the book? And crossing all your T's and dotting all your i's? Fairly anal i do it by the book
Do you tow up and over the Rockies? yes we like the rockies but we are also now becoming more truck camper people
How many towing miles per year vs empty bed truck miles per year do you drive? 1/2 and 1/2
Can you get 10 gallons of B99 biodiesel locally and add a quart of it to every 12 gallons of diesel fuel you buy? no
Because all of these things affect my answer.
If you drive conservatively, slowly, don't push it hard up grades in the heat and slow down, mix some biodiesel in in the spring, summer and fall in your fuel, to about 50:1 or 100:1, then keep it.
If you drive like a bat out of hell, sell it. Treat it like a tool, it'll break, treat it like a fine instrument, and it will last, and is a keeper. A HPFP needs slippery fuel, like a 2 stroke needs oil in it's gas. That's where biodiesel comes in, especially under heavy loads and lots of fuel being burned, like when trailering.
What about the fact that I use stanadyne isn't that any good? Also if the pump gets replaced do they put the same POS back in. At this point trading etc I am going to spend at least 10k to begin with.
