covered_wagon
Nov 19, 2022Explorer
Mine is always connected ready to go. It has a box covering the connection with a door for access. The box has a long tube attached in the rear for the hose to slide and go into which leaves room for fittings in the box.
I open the door, pull out the hose, attach the 90 degree fitting and dump the grey water last to rinse the hose.
When done the hose stays attached and slide the hose back into it's tube and close the watertight door.
I never need to connect nor disconnect the hose this way also eliminating the need to R and R the cap.
