Too new, IMHO, for a analysis to show much...unless you drive it VERY HARD...
Am not a fan of these tests on a regular basis...maybe if suspect something
amiss...like getting coolant in there or some such
Am OLD and lots of experience wit.h ICE lube/grease/etc...found that
*ALL* of the military contracts was assigned to design stuff for
while in college and after in my early life as a designer...spec'd
out MolyB. Researched and found the wonderful qualities...it is
now in most lube...but not enough, IMHO
Used Molybdenum Disulfide, 1.5 Micron Powder. Experimented with
Tungsten Disulfide powder, but going back to molyb...as the price
and particulate size has come down dramatically!!!!
Plates all metal parts inside any ICE...
Most larger displacement do NOT notice until tens of thousands of
miles later...but...small displacement will or might see it
in a few hundred miles. Mainly in the coolant temp. Now that IR
guns so affordable...set a datum before adding
Bought a $5 Oyster blender at Goodwill and use it to mix in MolyB
powder with Mobil 1. Just one quart and pour it in after 2 quarts
Mobil 1, then the other two quarts after
DO NOT use molyb in anything that has a clutch/friction material.
It will plate and friction goes out the window
Best engine oil filters are in the +3 micron range, so anything
smaller will pass through and plate the engine parts
Also use this in my guns, lawnmower, portable air compressor, stationary
air compressor, transfer case, etc...again...not in anything with
a friction material...to slippery and will ruin it
Not necessary for every oil change, but at least every third oil change
Here is where I get mine now...where it was expensive and specialized
before
Amazon and do a search using: "Molybdenum Disulfide / 1.5 Micron Powder"
Molybdenum Disulfide / 1.5 Micron Powder / 2 Ounces / 99% Pure / SHIPS FAST FROM USA
by Loudwolf
Price: $8.99 + $4.62 shipping
In Stock.
Ships from and sold by Professor Fullwood.
Eligible for AmazonSmile donation.
Estimated Delivery Date: July 6 - 9 when you choose Standard at checkout.
TOTAL WEIGHT OF PRODUCT: 2 Ounces
TOTAL VOLUME OF BOTTLE: 4 Fluid Ounces
TEXTURE: Ultra-Fine Powder (1.5 Microns)
GRADE: Reagent Grade 99% Ultra-Pure
CAS #: 12033-33-9
{edit}...here is an old thread with more info on molyb
What would you do?molybdenum molybdenumdisulfide molyb
PS...reminds me...my grease gun isn't working after loading it with
molyb rich grease...think the old cartridge left a bit of foil in there...
gotta fix or buy a new gun...
