I have used the Andersen hitch for 2 years on 2 different campers. I really like it for the reasons stated above. However, I would be concerned about using it on anything with a tongue weight above 700 pounds or so. Then I would want some definitive experience from other users at those weights. For smaller and lighter campers, the Andersen is the best choice as far as I am concerned. Easy to use and set up. Neither camper showed any slip problems on the tongue and, so far, no problems with the taper and brake material. Overall, it has worked exactly as advertised.
