mrkoje
Jan 21, 2015Explorer
transamz9 wrote:
If you don't mind the engine revving to get to it's power the 6.0 gas I believe has as much power as the D-max. Depending on the loaded weight of the 5er I believe it will do just fine but it will be at the top end of the tow rating.
You will probably have a bit more HP (way higher RPM) with the gasser but at half the torque (also at higher RPM).
