jerem0621
Jan 21, 2015Explorer II
Depends on your use.
If you want another diesel then there is nothing else to convince you otherwise.
For me, a truck would mostly serve as a commuter, family car, deer hunting truck, and heavy hauler on vacation. I would spring for the gasser.
It really depends on what you want to do with the truck and your expectations.
The 6.0 gasser has 90% of its available 380 lb/ft of TQ at 2,000 rpm, 360 HP is nothing to sneeze at.
As long as your not RPM adverse then the gasser could work.
But if you have it in your mind that you want another diesel... The gasser will not work... Even if it has 500 hp.
Thanks!
Jeremiah
Thanks!
Jeremiah
