jerem0621
Jan 22, 2015Explorer II
rhagfo wrote:jerem0621 wrote:
Depends on your use.
If you want another diesel then there is nothing else to convince you otherwise.
For me, a truck would mostly serve as a commuter, family car, deer hunting truck, and heavy hauler on vacation. I would spring for the gasser.
It really depends on what you want to do with the truck and your expectations.
The 6.0 gasser has 90% of its available 380 lb/ft of TQ at 2,000 rpm, 360 HP is nothing to sneeze at.
As long as your not RPM adverse then the gasser could work.
But if you have it in your mind that you want another diesel... The gasser will not work... Even if it has 500 hp.
Thanks!
Jeremiah
I want my TV/Daily Driver to tow Heavy very well, and being a soft riding DD, I will put up with a little harshness in my daily drive and some noise for a TV that is FULLY capable of pulling it's load at speed on the two lane roads to the Coast. You may not mind going 35 mph up a grade, but the 15 cars behind you sure might.
I did once pull a steep grade (I cant remember how steep the 4 mile grade was) at 35 mph at the top in my 235 hp 5.4 V8 f150... I was pulling a 7700 lb trailer with 3.55 gears. I kept the motor revving in the powerband but 235 HP can only do so much when coupled with 3.55gears.
The new Chevy 6.0 with 4.10 gears would fly up a grade. 360 HP with the right gear and an operator not afraid to let it rev where the motor makes power. No problem.
My dad has an 03 Cummins ram...he pulled Monteagle...foot to the floor at about 45-50 MPH with a 14k lb load. Said that he thought something was wrong...because "it's a diesel".
I am not hating on diesels...just giving options and my .02.
Thanks!
Jeremiah
