treyster wrote:
-Does everyone use a water filter when hooked up to city water?
-Does everyone have a surge protector and what kind? Seems Progressive Industries has a nice surge system but is about $250, is something else better? Do you have a lock for it?
-Do you use a water regulator and what pressure should I aim for?
-My trailer has 2 dumps. Do most of you just switch the sewer back and forth or do you Y them together?
Usually a personal choice for the water. At a minimum I would suggest at least the camco in line one. Its fairly inexpensive.
Surge Protector is a must. Progressive many swear by it, I have the inside one.
Water regulator I feel is a must. Never know what kind of pressure there might be. You can get the basic one or upgrade to adjustable.
Not sure what you mean switch back and forth. You probably have a grey tank dump and a black tank dump, dump black first then grey.
Search the forum and you will find a lot of good information.
