tatest
May 05, 2017Explorer II
Depends on which truck. Before choosing, check out the capacities and ratings for each truck you are considering. Some small trucks are more capable than others. Newer models are a lot more capable than small trucks from the 1970s and 1980s.
Equipment choice can be crucial, factory towing packages might add 1000-1500 pounds to tow ratings and 150-250 pounds to allowable tongue weights. My 2001 Ranger was limited to 2500 pounds, could have been 4000 properly equipped.
Since the 2000s when small pickup 4-cyl engines got into the 2.5 liter range with 150-200 HP, towing capacities could be as much as 3500 pounds for a 4, sometimes 6000+ for a V-6. You'll usually have at least 600-800 pounds load capacity to deal with passengers, cargo and tongue weight, maybe a lot more for lighter trucks (e.g. regular cab).
In recent years, small 4-cylinder trucks have gotten hard to find new, as formerly compact lines have been sized up to mid-size four-door models, with 3.5 to 4.0 V-6 engines as standard equipment, except maybe the occasional work truck. Nissan and Chevrolet/GMC are still putting a 4 in their mid-size trucks, but dealers don't carry many in stock, more likely to order for fleet buyers.
Do you have a particular truck in mind? New Colorado has a 200 HP four, rated to tow 3500 pounds with the tow package.
