egarant
Mar 12, 2018Nomad
ARB Lockers
Hi All, I am exploring the possibility of installing an ARB lockers on either the front/rear or both axles. I currently have a limited slip in the rear axle. My ONLY reason to install an ARB ...
twodownzero wrote:While this is true the Truetrac acts very differently than a clutch type limited slip. The gear driven mechanism is the only differential that both differentiates and transfers torque at the same time. The more it slips the more torque is transferred and you will not be just spinning one wheel unless it is completely off the ground.
A tru-trac is a limited slip, not a locker. It doesn't ever lock up.
