JIMNLIN wrote:
One big fib was 1/2 tons have nearly the same brakes as a 3/4 ton. Brakes are a axle rating function at a minimum... example;
A F250 Ford with a 6k fawr and a 6340 rawr = 12340 lbs of braking performance
A F150HD Ford has the heaviest specs with a 3750 fawr and 4800 rawr = 8550 lbs of braking performance.
^This is about as silly of an assertion as saying a HD 1/2 ton is as capable as a 3/4 ton because the payload rating is the same or similar.
Yes some numbers are arbitrary when talking vehicle ratings and some aren't. All have some sort of factor of safety on them.
Trouble is, alot of people who profess to know what they're talking about wouldn't know a ring gear from piston ring.
Lbs of braking performance as it relates to axle capacity....not actually a thing.
