westkill
Jul 23, 2017Explorer
Arctic fox: you should be ashamed of yourselves!
I have an 01 1150 model for the last few years
. Love the unit and have done repairs such as rebuilding the entire bunk area to fix the balsa wood, scotch tape and bubble gum the factory used. It no longer sags and rests on the roof of my truck. This year I tackled the giant belly under the slide out. I disassembled and removed the 2x3 they felt would support the entire weight of he slide,dinette and fridge. It now has a steel beam wth welded uprights going right to the roof. Even after this, the right rear still sagged and would Almost rest on my bed rails. Today I removed the lower 1\4" piece of plywood that slides along your wheel wells and was crushing to reveal not rot, not water damage or broken struts. The factory put absolutely NO framing there. There was nothing to keep the bottom of camper from crushing right up other than
N the. 1\4" plywood! In the pics you can see the water tank that was just bouncing around there with huge belly in between each of the 2 strts they put in.. there was NO insulation in the floor. So much for a 4 season camper! Where the rear sawhorse is is where the end f my truck bed is. The rest is overhang. .there is no structural support at all. A high school shop classs would frame it better.
I am adding a solid 2x10" in the open area going rearward. I have already framed in the area in front of the water tank and mounted that properly. Of course the rear was sagging, there's NO wood there! Needless to say my opinion of this manufacturer is zero! Look at he right front corner, they didn't even put wood on the corner!!!!!! Who the hell does that? So if you have a heavy camper with a big rear overhang this is why,absolute garbage construction and quality. Pics are below the next response
