rhagfo
Mar 15, 2014Explorer III
06Fargo wrote:
Our creaky old Cummins powered truck (bought used) seats 4, does about 20-23mpg bobtail and 12mpg towing a 5th wheel trailer at 22,999lbs. It's mileage is somewhere in between hauling a camper and/or towing smaller trailers. 1500 rpm to 2100 rpm in road gear. 1500 rpm to 2300 rpm in climbing gears. It's happy as can be hauling 1-1/2 tons in the bed when necessary.
Nothing I'd like better than to replace it when the time comes with a quiet gas engine truck that will haul 1-1/2 tons, or tow the 5th wheel at 22,999lbs etc and deliver the equivalent $/mile fuel economy in gasoline dollars. I would like it to maintain the hp I paid for at 5000-7000 ft. and not be too frantic in the rpm department every time it sees a hill coming.
Anything coming on the market that will fit the bill?
Have you visited your local Ram dealer lately??
Heck I test drove a 2011 new several years ago, and if I had not looked under the hood before starting would have guessed it was a gas engine.
Modern diesel engines are all of that.
Turtle n Peeps wrote:
#1. POWER
#2. MILEAGE
#3. LOW RPM
Pick any two and I can build you an engine for your needs, but you can't put #1 and #2 together. They are at opposite ends of the ruler.
Turtle n Peeps, I am sorry if I don't understand this post, but I seem to have all three with my Cummins. :B
This is true for all three of the big three, it is not necessarily true for the gas version of the same trucks with gas pulling the same load.
44,025 PostsLatest Activity: Feb 06, 2025
