Grit dog wrote:
Lwiddis wrote:
Some might think the seller wise for not advising you. No advice, no liability. And probably thinks you want your money back. As Is sales can be problematic.
Really? What world do you live in?
The one where the seller is not responding to the OP's requests for information before he makes the entire 16 hour trip there only to find out he can't load the camper.
Now, can the front "hoop" be removed without severely compromising the Stable Lift mechanism? If so, it is a simple matter of putting the Stable lift up on some blocks to raise the camper high enough to get your truck under it. Raise the camper up on blocks, then remove the front hoop and back under. Replace the hoop, suck the stable lift up under the belly of the truck, and hit the road.
