Ben
In the state of Washington, on my registration it is GVW! NO BLINKEN R after all this. I've been pulled over and had to go thru weigh scales with many of my trucks. NOT ONCE< when over a door sticker, but under my paid for license have I had issues. And the one time I was over paid for sticker, 150% of door sticker, as noted a few posts back, I was give a 10day to up the gvw from 26K to 28K lbs. I had another 2000 lbs, 1000 per axel before I would have been over the max amount allowed me under the "federal bridge law". THis is the weight law EVERY on gets in the US. If you are reduced to less than this, you can go to the Federal DOT, explain, show the ticket, and that state could lose federal funding of roads! In fact, the weight law section here in Wa st, says, The weight law enforcement will be done in a way as to NOT lose funding under the FBL!
A manufactures GCWR has absolutely NO meaning to ANY LEO/CVEO on the road. only in a civil court will any of the door sticker/warranty max weight numbers be a difference. And even then, not always.
In my state, I get licensed at 1.5 times the tare, based on manufacture number, or scale wt if the truck chassis was incomplete at the chassis manufacture. Then up this number to the next higher ton! So a rig that weighs 7500 empty, 1.5 times is 11250, so you would be buying a 12K license tag. Be it an 8600 min door tag rig to as much as just over 11K SW rig, or a dually!
ANY LEO or CVEO will tell you here any way, the door sticker is a warranty performance amount set by the manufacture. They enforce the "ENGINEER" rating of the road bed itself, NOT the "engineer" rated limit set by the manufacture. Two different engineers here, with different specs they design too!
In the case of the OP, he probably has 265 or 275 tires, or around 10.5-11" wide, he would get say 11" times 500 lbs per inch width of tire, so 5500 per tire, 11K per axel, or max 22K gvw going down the road. Not too many will recommend this, including myself. If he is truly on the road, he will also have to follow braking limit laws, which IIRC is stopping his rig within 25' at 20 mph. If he can not do this, he has a red tag, non drivable rig on the side of the road until the brakes are fixed so he can meet this figure! THIS is a moving violation, if over the 22K lbs gvwr, assuming he has a paid for registration equal to or greater than 22K, that is a NON moving violation and does not follow him on his driving record, as per the federal bridge law.
I know of a few folks that do long haul, max legal is 105K for a given setup here in Wa st. If one goes into Louisiana, it is 70K max. So they ticket one something like $400 for coming across the border over 70K lbs. You pay the ticket they let you drive thru the state. Cheaper to pay the $400 ticket for the truck company, than take off 25-30K lbs of product so they do not have to pay the fine.
At the end of the day, the paid for tonnege registration, is collecting the fee for the damage you do driving that rig across the road. So the state, taxpayer etc can rebuild the roads when the time comes.
Marty
