ScottG
Dec 13, 2014Nomad
Hannibal wrote:ScottG wrote:Hannibal wrote:
Even the halo sporting Honda Accord suffers from carbon buildup in their EGR valves. There's a TSB on it. If it can happen to a Honda (hear the angels sing!) it can happen to any of them.
The problem with the EB is not carbon on the EGR valves, it's carbon on the intake valves. A much more serious and difficult problem to correct.
A quick Google search indicates this isn't limited to the Ecoboost engine at all. My '95 and '98 Cummins engines vented their PCV to the atmosphere through a down tube rather than suck it back into the intake like the newer ones do. I did this on my Harley as the PCV fed oil mist into the air cleaner and carburetor. Difference being gas vapor helped keep the intake valves clean. I wonder if venting the Ecoboost to the ground would keep the valves cleaner.
I'm sure it would but not only would dumping it on the ground be a messy EPA issue, it would also be a problem because the engine needs EGR to help cool combustion and keep tail pipe emissions down.
On a turbo gas engine like the EB, getting rid of EGR would result in not only high emissions, it would also result in pinging.
EGR valves have got to be one of the worst inventions the industry ever came up with. They eventually cause problems in just about every engine.
44,056 PostsLatest Activity: Jan 12, 2020
