Gdetrailer wrote:
goducks10 wrote:
I added some driving lights to the rear bumper....
However instead of using a manual switch you do realize that the 7pin connection on your vehicle already HAS a backup light circuit?...
I like the idea of driving lights, and maybe the best thing is to go through the hassle of running the wires to the back of the trailer. I have an enclosed underbelly, but there might still be room beside the main rail to run the wires. I'll have to investigate that.
I would also need to test the reverse terminal at the plug on my TV to make sure it indeed does work as a reverse circuit. If it does, then maybe hard wired is the way to go. I know the options for lights that are effective enough will be much better.
The other thing to investigate is mounting options for lights. I don't really want to run screws into the rear bumper, as I store the sewer hose in there, and it would probably snag on them.
Thanks for everyone's suggestions.
