SoundGuy
Feb 26, 2016Explorer
Sam Spade wrote:
Except that it may be REALLY inconvenient to get a main cable from BOTH sets of batteries routed to one common place to go through a switch.
It really is best to have a switch for each one, mounted at a point near the battery so that you don't have to extend the heavy gauge cables.
Disagree completely ... done correctly there's no reason at all to not use a dual battery switch as I described earlier. In fact, I'll be adding one to my own trailer this spring when I also install a pair of G31 batteries to replace the current G27 which itself is wired through a similar Blue Sea m-Series Micro single battery switch.
