- Gene_GinnyExplorer
tshirtman wrote:
Here is the back side of that switch. The "com" on the left is the common line to the trailer. The + of one battery goes to the post on the right, the + of the other battery goes to the post on the bottom. You can select either battery or both batteries or disconnect entirely.
Ok OK, just tell me if you can run both rv batteries in (aluminum box) on ONE disconnect,????...
- tshirtmanExplorerThanks Westend---
your reply was the most helpful:) - westendExplorerYes, you can use one switch.
The paralleled 12V batteries or series connected 6V batteries are connected like a single battery with one (+) cable to the inside of the RV and one (-) phase cable to ground (frame). The switch is connected in the (+) cable, located where convenient.
It is a good idea not to switch the breakaway switch but connect it directly to the batteries. - beemerphile1Explorer
Do you have the Utube link to install. I only see the install vids for single batteries.
thank you:)
Yes, yes, yes, yes, yes! again - tshirtmanExplorerOk OK, just tell me if you can run both rv batteries in (aluminum box) on ONE disconnect,????
thank you:) - Community AlumniThe OP asked how to wire a switch to disconnect both batteries. A Blue Sea 6007 does that job. I'm not sure what all the animosity against the 6007 setup is all about. The switch costs virtually the same as the 6006, short runs of low gauge wire can be had for next to nothing, and you get some flexibility with battery use. When I add a second battery I'll swap my 6006 out for a 6007.
- Boon_DockerExplorer IIIGEEZ, give it a rest already.
- Sam_SpadeExplorer
coolbreeze01 wrote:
I guess you have never been out so far you can't see the shore. We that have understand redundancy.
In your RV ?? No I haven't.....and don't intend to either. - Sam_SpadeExplorer
SoundGuy wrote:
Just like in a schoolyard - if you can't get your way just yell and maybe someone will pay attention. :S
Because you are not paying attention. Nothing you said refutes or changes the fact that using one battery at a time gives you NO advantage over just leaving them both connected......IF you have easy access to a charger. - Gene_GinnyExplorer
avoidcrowds wrote:
OK :B
Gene, stay out of this. ...
Actually it was SoundGuy's idea and I wanted to save a thousand words. ;)
44,056 PostsLatest Activity: Jan 12, 2020
