Lynnmor
Jun 29, 2020Explorer II
midnightsadie wrote:
there must be away you can disconnect both some kind of part you plug in.I,ve seen the after math of a battery explode ain,t pretty.
Start by removing the negative cable from both batteries. Replace batteries and connect negative cables last. Reset any settings that you lost and let the computers relearn all their things. I do the rubber glove thing to prevent loosing settings. You can buy memory savers that plug into the OBDI port or the lighter if it stays hot.
