scottykrug
Jul 05, 2013Explorer
Best replacement toilet?
The Aquamagic 5 that came with our camper has an annoying habit of letting out a nasty stink when it just sits. The bowl is full of water so the blade seal works fine. I researched this topic here and by google to find people with similar problems but no real solutions. It wasn't until I removed the beast that I found out a rather disturbing truth and possible connection to the stink. The area under the bowl is totally open to the smell of the tank, ie, when you flush, the contents literally flop down onto the base of the toilet and hopefully into the tank. There are many potential leak spots from which odors can come from (the actuator cable at the bottom of the toilet, the water valve at the top, or any possible cracks in the case along the way to name a few). I figured there would be a positive sealing tube to the tank not a giant open @#^$ collecting crevasse one thin piece of plastic away from stinking out your camper. Does anyone have a suggestion for a better design? Don't have a lot of room behind so one of those enormous bravura toilets won't work. I have looked online and they don't really give info regarding how their toilets work. Thank you!
Scooter
Scooter
