- BeMurdaExplorer
Grit dog wrote:
BeMurda wrote:
Grit dog wrote:
BeMurda wrote:
I think I will stick to fiberglass or aluminum types of construction. Lance, Wolf Creek, Northern Lite,
There is a Lance 950S with factory weight 3154 that I really want to look at getting but should probably go lighter. I did order the highest payload Dana rear axle.
You’re not quite understanding the camper construction types.
Aluminum is used in reference to the basic frame skeleton vs wood. I noticed zero difference between our 2 TCs which were identical except the wood one was older and we owned it longer. There’s still copious amounts of wood in most any camper that will be damaged by leaks. If it’s to the point that the frame is rotting it likely already has more damage than feasibly repairable to the other wood components. And even an aluminum frame camper would be basically destroyed due to the “other” parts rotting or delaminating.
Didn’t notice any weight savings or vice versa either with our campers.
The fiberglass were speaking of is clam shell exterior. (which will still have a bunch of wood under it). But it won’t have the full length seams at every corner that are all potential leak sources.
And realize that there isn’t an axle option under basically any 3/4 or 1 ton truck from the last 25 ish years or more that isnt rated to around 10klbs capacity. The axle is actually the strongest part of the truck equation for HD srw trucks. You didn’t get anything special axle wise to figure into your acceptable payload decision.
Yes, I did know all that about the construction, but it is still a good summary thanks :)
Regarding the axle, I'm sure you are correct that they are all rated for far more. What I was referring to is the Dana 4.30 axle increases the GVWR 400lbs relative to the Sterling 3.73 axle.
I also picked the 18 inch wheels and AT tires with the highest rating from the factory.
Actually you don’t understand any of it if you think deeper gears increases payload.
You could easily haul a 4400lb Truck camper around on a 30 year old F350 with a 351 Windsor and whatever gears they came with.
And 18” OE rims dont carry any more than the 20s.
You’ve ordered a very nice truck, congrats and good luck with your search for a camper.
Not sure where that tone came from, no, I don't think deeper gears increases payload in and of itself. On the 2023 F-350's, opting for the Dana 4.30 axle over the Sterling 3.73 axle, with the right tires, increases the GVWR by 400lbs. In fact, it's the only way to get the 11,900 GVWR package. - jimh406Explorer III
Grit dog wrote:
Oh ok….lol.
Hard to believe someone whose had that Host in your pic for god knows how long would actually say that….
It will be 17 years in May with no leaks. The seam sealant is super easy to replace and visible if it's cracking. Window and marker light seals aren't very visible.
You've been around here for long enough to hear about the marker light leaks and window leaks. Fwiw, my Host doesn't have front marker lights or a front window.
In theory, Bigfoots and NorthernLites wouldn't leak, but they do. Again, they aren't leaking through the clamshell, but windows and marker lights.
Fiberglass boats don't usually leak unless you drill or cut holes in them. The same goes for TCs. - Grit_dogNavigator II
jimh406 wrote:
Grit dog wrote:
They have probably 50' less of seams that are susceptible to leaking compared to the other style of TC construction. Idk why you'd say that.
Because seams aren't usually where they leak.
Oh ok….lol.
Hard to believe someone whose had that Host in your pic for god knows how long would actually say that…. - Grit_dogNavigator II
You’ve ordered a very nice truck, congrats and good luck with your search for a camper. - BeMurdaExplorer
I also picked the 18 inch wheels and AT tires with the highest rating from the factory. - StirCrazyModerator
BeMurda wrote:
Hi all,
Looking to buy my first truck camper, used. Looking relatively modern (less than 15 years old) with good construction and power jacks. Are there any models you recommend for this size truck? Any that you think would be ideal?
What should I look out for as a first time buyer? Thank you.
what other things are you looking for? we originaly bought a 1991 slumberqueen as it got me into the truck camper market for cheep. we are looking at upgrading next fall and have used the last 3 years to decide what we want in a new camper. I want a single slide, a forward bathroom, etc... I am looking at the same weight range as you and I have narrowed it down to eagal cap, adventure, lance, and artic fox. I ruled out bigfoot and northren light (both made localy to me) because they don't have the option for a slide. now if you don't have a 92 lb lab you may not need a slide which you could add them back in. at this time of year they are still way over priced for a new or used one and there is almost a year waiting list for new.
weight wise I am looking at around 3500lbs on the sticker plate to keep me in the range I can handle, you could go a little bit higher depending how much stuff you take with you for adventure, I am looking at there 910db has lots of outside storage that is usefull and a layout that we like. - jimh406Explorer III
Because seams aren't usually where they leak. - Grit_dogNavigator II
And realize that there isn’t an axle option under basically any 3/4 or 1 ton truck from the last 25 ish years or more that isnt rated to around 10klbs capacity. The axle is actually the strongest part of the truck equation for HD srw trucks. You didn’t get anything special axle wise to figure into your acceptable payload decision. - otrfunExplorer II
jimh406 wrote:
Most would agree any truck camper can experience water intrusion.Grit dog wrote:
Not true since almost all of the water intrusion reported here comes in around marker lights with a bit from other openings in the top for vents, etc.
The fiberglass clamshell types like Bigfoot are less susceptible to water intrusion.
However, any TC that uses only fiberglass and/or aluminum (i.e., no wood) for structural support of the cabover and jack legs will be much less likely to experience a sagging cabover or loose/collapsing jack legs resulting from water intrusion. These are arguably the two most serious structural issues one can have with a TC. - JimK-NYExplorer IIGood luck. In my area, there have never been many used truck campers for sale. Now is worse than ever and also very poor for new campers with minimal inventories and long delays for custom orders.
44,050 PostsLatest Activity: Sep 08, 2025
