Ron3rd
Jun 22, 2018Explorer III
transamz9 wrote:Ron3rd wrote:
Does anyone know a better way to change the rear fuel filter (water separator) on a new generation Cummins without getting showered with diesel fuel?
I've done it twice now and always get a lot of fuel pouring out when I loosen the filter. I open the drain prior as required, but it seems a lot of fuel remains somewhere.
BTW, don't have a lift, can only do it on my back on the ground.
It has a spring loaded check valve. Unscrew it a couple turns before opening the drain.
By "unscrew it", you mean the filter or the plastic sensor at the bottom?
