cummins2014
Jun 25, 2018Explorer
Cummins12V98 wrote:Greene728 wrote:
Get a section of 3/8 “IIRC” drain tubing. Attach this to the hose bib on the drain and open the drain with the tube in a jar, pail, whatever. Once it stops, loosen the filter a turn or two and break the seal/check valve and it will then begin completely draining. You are gonna get a little bit as it just is what it is. But, should not be a mess or more than just a couple ounces or so, if that. It’s really pretty simple this way and the bag has never been needed for me doing it this way. I actually bought enough hose and left them attached and tucked out of the way as someone else mentioned on front and back. Also, invest in a Fumoto drain valve for the oil plug. It’s simply wonderful Easy peasy.
GOOD advice! BUT not a fan of the Fumoto as it will leave more oil in the pan than just pulling the factory drain plug. Also don't like the idea of a prankster.
I just bought one for the 350 in my boat.
Good grief , pranksters , I can just see all of them running around looking for a fumoto drain valve to open. Now I have heard it all, and you were serious :@
I do agree on the oil left in there, I pull my fumoto, was very surprised at how much oil is left in there.
