srschang
Oct 20, 2022Nomad
This spring I was pushing my 2 year old Northstar 12 STC out of it's storage position in my pole barn to the middle bay where I load it onto the truck. Unfortunately, I hit my wife's Bowflex workout thing, and punched a couple holes through the front of the camper. After doing the body work to repair the holes, I needed to find matching paint. We have a NCS (National Coatings and Supplies) not too far away. They have a camera thing that they put up to the surface of the camper, and somehow they can mix the matching color and put it in a spray can. I think it was $40 or something, but it matched close to perfect. My buddy who has a body shop looked at it and said he couldn't see a difference.
Then I topcoated it with USC SprayMax 2K Glamour High Gloss Aerosol Clear. It's a two part acrylic resin. There's a button on the bottom of the can you push in to burst a packet inside the can, then shake to mix. You must spray within 48 hours or it solidifies in the can. It sprays very high gloss, and is hard as a rock, even hard to sand.
The only thing I can see from the repair is a difference in gloss around the repaired area. In the right lighting I can see a 1'x2' high gloss area surrounded by a 6 or 10" lower gloss area. Probably didn't hold the spray straight on at the end of each pass. I should probably mask and spray the whole front of the camper to have a consistent gloss, but it's pretty low on the priority list.
