lanerd
Jul 28, 2014Explorer II
Crawfordville wrote:
What is an in-tank rinser? Our camper has a valve on the outside that allows to rinse the black tank by hooking up a hose. Is that what you're referring to?
Yes. When your tank is about 2/3rds full, and before emptying the tanks, turn on the water for this valve and it will put fresh water into the tank. Be very careful that you don't overfill the black tank as it will create a really bad mess inside the rv. Just as soon as the full light comes on, open the black tank dump valve (leave the water running into the tank). Add more water to the black tank so that it will be there prior to using the toilet. About 5 gals will usually be sufficient. BE SURE TO TURN THE WATER OFF TO THE BLACK TANK!!!!
Posted By: DutchmenSport on 07/28/14 10:45am
Don't know what kind of camper you have, but let's assume your black and gray water Y into the same outlet. If they do, here's a trick that REALLY works.
First you need to purchase a 3rd valve, like a flush-king
Camping world sells them, as does any RV dealership.
What you are going to do is back-flush the gray water into the black tank.
Step 1. Attach flush king and open the valve.
Step 2. Open the valve of the black tank and let everything drain until it stops.
Step 3. Close the flush king.
Step 4. Open the Gray valve and let the water back-flush into the black tank for about 5 seconds then shut the gray valve again.
Step 5. Open the flush king valve and the black valve and you'll be amazed how much MORE will come out of the black.
Step 6. Repeat steps 2 thru 5 two more times! Each time will pull more and more out.
Step 7. Once done, close the black and open the gray and open the flush king, and let the gray finish draining, cleaning out your hoses.
This simple process will pull a LOT of stuff from the black tank. You'll be amazed.
The secret is to get a flush king valve, or something similar, with a clear section where you can see what's coming out.
About TP... any brand that works for you! The secret is the amount of water to flush it out of your black tank!
This is also excellent advice. Be aware that if you have space limitations, you don't necessarily need a "Flush King" as you can purchase a 3rd gate valve, without the extra clear tubing and hose connector, that is much smaller. Granted, the clear tubing allows visual inspection of exactly what is coming out (dirty or clean water) and gives you a better idea of what's happening. I installed a 3rd gate plus a short clear connector on mine and I follow the above instructions.
Hope this helps
Ron
44,066 PostsLatest Activity: Apr 10, 2026
