rbpru's avatar
rbpru
Explorer II
Aug 31, 2017
Boondocking and Phantom loads.
I am curious what the serious boondocker does about the phantom loads in there TT.
The few time I needed a non electric campsite I turned off the antenna booster, switched the Frig and water heater to LP, pulled the fuse to the radio/DVD player (that caused the blown fuse LED light to come on) and I have switch all my lights to LEDs.
At this point it seem the LP detector, Frig sensors and perhaps the water heater circuit are still drawing power. I measure about 1/3 amp average.
My question is, do those who boondock a lot just live with the phantom loads or do they do something else?
  • Some Norcold refrigerators don't use any electrical power on propane. They do not have a thermostat but rely on manual adjustment of the flame size. Works better than it sounds.
  • Never seen an LP detector that closes any valve but I'm sure there is a first for everything. Not an LP detector as such, it's a Co detector. Your nose is the LP detector.
    In reality, your tow vehicle (if it's late model) has more 'phantom loads' that your camper does.
  • darsben1 wrote:
    What Phantom load?
    The fridge even on gas needs 12 volts to operate
    The LP detector needs 12 volts or the valve closes
    HW circuit is a variable
    Also consider if has heat pads on the tanks, mine turn on at 40 degrees if not on manual mode.
  • No issues for me since I installed solar...or with the TV, radio, lights, awning etc. Solar isn't a toy or fad. It works great for RVing. It wakes no one up or spoils a peaceful afternoon nap even though it is working.
  • What Phantom load?
