maxwell11 wrote:
it was for all four corners
may be a little high but I wanted a good set of pads,
in the pass I have had the long last super hard pads, but they made noise, I did not want that.
when pulling that travel trailer, I just wanted brakes in good shape.
just thought it best to ask before I had them installed.
do any of you change out the brake fluid? truck is 14 years old!!!!
NAPA's top pads, rotors and calipers are what I'm running and I'm very happy with them and how they stop.
Yes change the fluid out with DOT 5 brake fluid. But you MUST change or remove ALL of the old fluid first! You can pick up a brake vacuum pump from Harbor Freight.
Click me this is what I use works great.
Being it is a 05 you might want to replace the soft lines. I rebuilt my brake system last year including all the soft lines and the pedal is rock hard. If you change them you won't believe the difference it will make!
Don
Oh well should have read the whole thread before I posted. :o
