riven1950 wrote:
1- Local shop quoted Wagner pads but will likely use whatever I want. Problem is I don't know what is best. Any suggestions?
Wagner are good, but like most top brands they have more than one grade. You want the Wagner ThermoQuiet. These are ceramic so they should be low dust.
My preference is the Raybestos Enhanced Hybrid Technology. Also Ceramic
riven1950 wrote:
2- Thought I might get them to flush the brake lines and refill at same time. Good idea @ 60,000 miles or not?
Not worth the cost.
riven1950 wrote:
3-Rear brakes are still ok they say, although getting close. Any reason to do both at same time other than convenience?
Hard to believe that rears are "close". Most vehicles the rear shoes/pads "rot" before they wear out.
riven1950 wrote:
Local guy said they would measure them and turn or recommend replacement.
That is the correct answer ! Again, if you need rotors, you want premium brand rotors.
