dessa1930's avatar
dessa1930
brake shoes
i have about 10k miles towing on my 33 ft tt
thought i would check the brakes and pulled drum of
to my surprise i only one wheel had any brake lining left
i was stopping with only 1 wheel brake
do brake shoes not last that long on a tt
80% of travel is on interstate so i dont use them that much
they have never been overheated or never notice them dragging or running hot when on road
is this normal
  • No that's not normal. I have a 40' fifthwheel and have over 40,000 cross country mls on it and pads still looked good. I just changed over to disk brakes. I would say you're dragging your brakes or you have too much brake in you brake adjustment in your truck if they wore out that quick
  • Have seen several where the linings come off the shoe itself then break into small enough pieces to come out of the drum. Most found when checking wheel bearings and not a brake complaint. seems like the bonding agent failed to hold the lining. Some still had the lining loose inside the drum.
  • dessa1930 wrote:
    its a 2002 model and i did buy it new
    it has manual adjusting brakes
    several years since i have checked them as we only camp 1 time a year for a month at a time and its only about 250 mile round trip
    You’re insinuating that last time you checked them they didn’t show a great amount of wear?
    But you must’ve noticed they didn’t work right for how long?
    Regardless, none of that matters it’s 20 years old and from what you’ve described, no one could say whether that is expected or not.
  • its a 2002 model and i did buy it new
  • You did not say how old the trailer is but an awful lot of trailers have been produced with manually adjusted brakes and then lots more with reverse adjusting brakes. The newer forward adjusting brakes tend to be better but a yearly check when you repack the bearings and put a new seal in can give you an insight into how well adjusted your brakes are. You seem to have one that was adjusted too loose compared to the others and that is why it still has material left.
    When was the last time you checked them?
  • I find that unusual. Did you buy the trailer new to know the brakes only have 10K miles on them? I find the self-adjusting version run warmer as the shoe is always rubbing and have replaced mine with manual adjust versions.
