Gdetrailer wrote:
temccarthy1 wrote:
Lynnmor wrote:
The trailer is a dozen years old, so just pull the drums and have a look. It is way overdue for a brake inspection. You may find grease, rust, worn shoes, broken hardware or bad wiring. The bearings need to be inspected and repacked with grease and properly adjusted. All the advice people can give you from afar will not give you a trailer that is safe.
AMEN to that!
Gee whizz folks.. Get a grip..
The OP POSTED THIS..
"When TT is hooked up and brakes applied a buzzing sound is heard but no brakes are working. We pulled the break-a-way switch and no brakes. Got an estimate for diagnostics of $50 applied to work if done.
Would like some more input from here as to what we may expect."
SOOOO I don't think the OP was planning to use or sell the trailer "as is"..
I suspect they are FULLY INTENTIONALLY WANTING TO GET THE BRAKES WORKING. They are just asking what they could possible expect to pay and/or what parts may be needed.
Possibly but they also stated this:
Any idea of what the cost would be to have them fixed. Do not want to spend alot on this well used TT.
To me that indicates the repair cost may exceed their comfortability level. Besides, if they the brakes absolutely need service, why ask, if the work is going to be done regardless.
