- 2112Explorer II
MorMJS wrote:
I have had sewer fly's in my gray tank coming in though my shower drain. I would pour water into the shower and sink drains every few days to keep it full in order to seal them out. After a few weeks they were all dead I guess. The problem was solved.westend wrote:
MorMJS,
Sewer flies resemble fruit flies. Were you recently connected to sewer hookups and had the tank valve open? The only cure I've read about is to spray bug killer into the black tank. I've never had this, or any other bug issue and not so sure I'd use gobs of bug killer into my RV. A mechanical cure with fans and open windows might eliminate most problems. Then again, it will be subzero here in a little bit and there are very few pests that make it through that.
I leave my sewer valve closed unless I'm actually draining. I even tried leaving toilet valve open to see if they were coming out of there and none came out from there.
Now I always run some water in all drains every few weeks just to keep them sealed and wet. - BzeithamExplorerSeveral years ago we had problems with insects on our sailboat. We set off insecticide foggers, available at most hardware stores, in the cabin and that took care of the problem. BUT make sure you have ALL appliances turned OFF! Another product that you might consider for storage is a product called SunPack. It keeps mold and mildew at bay. Not sure it is sold up north but is very common here in Florida.
- shenandoahvalleExplorerI've had problems with stink bugs getting in the TT. There is a cure on the internet that doesn't use poison that works well...plastic pan of water with a light under it...they get in a drown.
- MorMJSExplorer
westend wrote:
MorMJS,
I leave my sewer valve closed unless I'm actually draining. I even tried leaving toilet valve open to see if they were coming out of there and none came out from there. - westendExplorerMorMJS,
Sewer flies resemble fruit flies. Were you recently connected to sewer hookups and had the tank valve open? The only cure I've read about is to spray bug killer into the black tank. I've never had this, or any other bug issue and not so sure I'd use gobs of bug killer into my RV. A mechanical cure with fans and open windows might eliminate most problems. Then again, it will be subzero here in a little bit and there are very few pests that make it through that. - MorMJSExplorerSo I just picked up my TT yesterday to get it ready for a trip and I now have an infestation of flies. These little bastards are everywhere!! they even managed to get between the 2 panes of glass on the microwave door!!
I have searched the trailer top to bottom and cannot find any food that may have been left from last trip, but these look to be fruit flies.
Im not sure how to get rid of these. - BStrumminExplorer
rockhillmanor wrote:
1. Vinegar and coconut oil in a spray bottle and sprayed around the ceilings, walls and around all sinks to keep the spiders out and from breeding. Makes your RV smell nice also.
Huh. I've never heard of this one. Thanks! - rockhillmanorExplorer IIHere is what I did to eliminate ALL of the bug and critter problems when storing the RV for the winter.
2. Go underneath your RV at night with the lights on inside. Plug all the holes where the light comes thru to keep ALL critters big and small from getting inside. You 'will' be shocked how many holes you will find!
3. Go to any farm supply store or Tractor Supply and pick up a couple of rigid 'Starbar Fly Stik' fly sticks and hang them in your RV. I use the removable 3m hooks and hang 4 of them from the ceiling from front to back. These are the bomb for attracting/getting rid of fly's and many other type bugs.
http://www.horse.com/item/starbar-fly-stik/SLT300094/
http://www.statelinetack.com/item/starbar-fly-stik/SLT300094/
Come spring you won't have mice, spiders, bugs or anything flying, crawling in your RV to clean up. Just take down the strips and go RV'ing! :C - DutchmenSportExplorerJust place a citronella candle in the camper and shut the door. Do not light it, just let it sit there. You'll have no bugs. We keep one in the front and one in the rear of the camper. Never had bugs of any kind. It works well in the summer to when camping. No fire, just the candle.
- dadmomhExplorerOur invasion was lady bugs. Everywhere you turned...more. They seemed to love the large rear window where it was warm and you could see through the day shades to all these little critters. We'd gather up a handful and toss them out the door. Went on for weeks and I THINK we've finally got it under control....haven't seen any for about 6 weeks. Hadn't thought about asking our bug guy how much extra to spray the trailer....he's a long-time friend and I'd bet the answer is $0. I can afford that! For winter, we've always done the fabric softener sheet thing....according to some it works great, according to others it's a waste of time. In any event, we've never had mice or other critters and the trailer does smell wonderful. For a couple of dollars, we'll do it again for whatever reason.
44,068 PostsLatest Activity: Jun 20, 2026
