If you are okay with picking the upholstery from a small picture, then I would say yes, with the following qualifications.
Make sure the salesperson does an extensive walk through with you and demonstrates all of the appliances including the water heater and furnace (Plan on staying long enough for the water heater to cycle through 2 heatings) BEFORE YOU SIGN THE PAPER WORK ! Test water, from both the city connection and fresh water tank as well was gray and black water valves.
If they won't do that, find another dealer.
If the TT does not come with a 2 year warranty push hard to have one added. Also press for a warranty on appliance to be the same as the TT.
